Old 08-15-2008, 02:35 PM
Kent_Norway Kent_Norway is offline
Kent_Norway is on a distinguished road
The spec for file formats on our DSPs
I have been rereading some of my machines spec and I was not sure what the lines which says
Command: G Code, *uoo, *mmg, *plt
means in respect of SW outputs? For those who use V Carve pro, is it standard ISO G code you use or is there any other custom setups you use for this (Note I do not use V carve pro, I do have a demo version downloaded but never got to try it).
The question is related to if I should use another SW package than Ucancam, what format do the DSP accept ? In larger SW packages the output files (G codes) need to be translated to you're/our machines which is usually called "post-processors".
So the *uoo, *mmg, *plt is not perfectly clear for me what means.
Any one ?
Kent
