Well, let's see, the length of the taper is different, and the position of the flange is different, so unless your machine manual says 'use this pull stud for CAT and this for BT' you are going to have to do some figuring, are you not? since this is NOT the case on a Bridgeport as the OP has, it is not 'quite' that easy.
Those dimensions seem straightforward, but try measuring them in the machine....
In the case like I went through, where there is not any factory called out pull stud, you have to do the math and find a stud that looks right[ the cat needs ~.15 shorter pull stud] and then put it in the machine and see if all the clearances are what they should be. In the OP's situation, I think there is a factory pull stud to bring a CAT machine back to BT, once he changes the drawbar fingers. There might be one to use without changing the drawbar fingers, but he will have to figure that out. |
