Thread: Macros
Old 06-04-2003, 09:50 PM
Turbine Turbine is offline
Turbine is on a distinguished road
Here's a mill one to blast a circle pocket without a start hole. It has slick helical motion. My favorite lathe one is in your email. (Sorry guys... It wouldn't be right for me to post that one here as I did not write it.)
  • O9001
    (VERSION 1.1 - 2/17/03)
    (X=X CENTER)
    (Y=Y CENTER)
    (Z=FINAL DEPTH)
    (B=BORE DIAMETER)
    (C=CUTTER DIAMETER)
    (D=DIRECTION, 2 OR 3)
    (W=DEPTH PER PASS)
    (R=START PLANE OF MATERIAL)
    (F=FEED RATE)
    #30=#4001
    #31=#4003
    #32=#4109
    #33=#5043-#5083
    IF[#24EQ#0]THEN#24=#5041
    IF[#25EQ#0]THEN#25=#5042
    IF[#18EQ#0]THEN#18=#33
    IF[#9EQ#0]THEN#9=#32
    IF[#26EQ#0]OR[#2EQ#0]OR[#3EQ#0]OR[#7EQ#0]OR[#23EQ#0]THEN#3000=1(INSUFFICIENT INFORMATION SUPPLIED)
    IF[#23LE0]THEN#3000=1(ILLEGAL W SPECIFIED)
    IF[#2LE0]OR[#3LE0]THEN#3000=1(BOTH BORE AND CUTTER DIA MUST BE GREATER THAN ZERO)
    IF[#26GE#18]THEN#3000=1(DEPTH MUST BE LESS THAN START POINT)
    IF[#26GT[#18-#23]]THEN#3000=1(W VALUE TOO GREAT)
    IF[#3GE#2]THEN#3000=1(CUTTER CAN NOT BE BIGGER OR EQUAL TO BORE DIAMETER)
    IF[#7EQ2]OR[#7EQ3]GOTO5
    #3000=1(ILLEGAL DIRECTION SPECIFIED)
    N5#29=#2/2-#3/2
    G00G90X#24Y#25
    Z[#18+#23]
    #18=#18-#23
    G01G91X#29Z-#23F#9
    N10G#7X0.Y0.Z-#23I-#29J0.
    IF[#18EQ#26]GOTO15
    #18=#18-#23
    IF[#18GT#26]GOTO10
    #23=#18+#23-#26
    #18=#26
    GOTO10
    N15G#7X0.Y0.I-#29J0.
    G#7X-#29Y0.I-[#29/2]J0.
    G00G90Z#33
    G#30G#31F#32
    M99
"The source of expertise is not in the memorization of the minute details of a subject but in the thorough understanding of the fundamental concepts on which it is based." --author unknown
