Since you cannot use the same pull studs, then you must change something. the length of the taper is different, and the thread is different, so you must change pull studs. once you change pull studs, then the fit into the spindle IS different. The tool umbrella is NOT related to this. The difference in length is something like .150. You must check your clearances to make sure that you chose the right pull stud if your machine does not list a direct swap
There is no reason I can see why someone could not have made a tool carousel that was either or IOW, flip it upside down and it is BT Actually the bridgeport, I think, you could mix carousel segments as they appear identical, but I haven't checked. |
