Camsoft should be able to help you out with these details. I believe you can go into the diagnostics screen and get an interactive sort of screen of all the i/o points. If you have the limits wired up, simply actuating them should cause a square to light up or else go "off". The location of the input can then be determined.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
