Old 09-30-2004, 08:13 PM
Darc Darc is offline
Darc is on a distinguished road
Camsoft Installation help needed...
Hi guys, I like the forum, good variety.
I'm attempting to adapt the Camsoft software/controller onto a Walter tool and cutter grinder, I've gotten the axis's to move (6 in total, but we will only use 5) there not moving the correct amount, I tried the gear/ratio but I think I messed it up, anyhoo's I don't really understand what counts to enter first (I put 4000) if I'm understanding this right any counts can be enter and after a bit of calculating you alter these until 1 inch on the display = 1 inch of movement?
Also with the home/limit switches, am I meant to set the variables (still a bit blurry) in the CBK file?
Other than these hiccups, which I expect many more, it is very easy to start using, little bit nerve racking when it first moved.
