s.1 and s.2 will switch between hi and low gear without turning on spindle.
the pistons your looking for are on the right side of the head as you look at it.
hope that helps
the pistons work on air pressure so when the air goes down the tension lets up, this could be a problem when torque is needed.
aint to good on the belts anytime.
try turning by hand to see if its binding up in either gear.
pinching between the gaurd and pulley could be the problem, ive had belts actually twisted once when we took them apart.
Reason: adding info
