zamzak you are correct that Madcam was made for mold and die making, but Joakim has been adding many features requested by wood workers, myself being one of them. There are many new features that were designed just for wood workers, some specifically designed for cutting of sheet goods. My suggestion, is email Joakim and ask him for the G2/3. I have been in contact with another Madcam user that wrote a script that will take the Madcam output and run it through a converter and so as to be able to use G2 and 3. I haven't had a need personally, so haven't pressed the issue, but I will also contact Joakim to see if this is something that can be incorporated directly into the program.
Mike
Originally Posted by zamzak G02/G03 is no issue for 3D (programs is large with or without). Problem is, when I make 2D parts with simple V-carving on it and have for one piece 10000 steps and make 10 or more at one CNC table. Program is simply too large to handle (Morbi's Xilog has its own interpreter from txt ISO G-code to his G-code) and take too much time to calculate, sometimes up 1/2 hour.
Yet make programs with Bobcad (make usable G-code, but CAD section is ..... horrible), but want to buy CAM software for my Rhino, to make work faster and without opening two or more CAD/CAM software at one time.
I found at Rhino3D page MADCAM, i think this software is just what i need, after make some test codes i realize, that doesnt't have arc movement.. i just can't believe it.
But after all, MADCAm is made por Mold&Die and not so much for us... woodworkers  |
