Old 09-29-2004, 02:40 PM
hughesbros hughesbros is offline
hughesbros is on a distinguished road
Mark,
You cannot edit or view g code files with the Eztrack software, you can only run or simulate the tool paths.
To load a G code program from the floppy drive you must be on the auto/run screen press the left arrow key (LOAD) this should bring up a file list, now press F4 to select the A drive and F5 to display all files with .txt extension select the g code file and press + to load. If you use the test file I posted before press the right arrow key to simulate, next press 5 and set the display size to -50,-50,50,50 and press + to simulate. Now exit the simulation and return to the Auto screen to run.
In England health and safety made Bridgeport retrofit all there Eztracks with extra guards and manual switches to select the different software modes Edit/MDI/SDI and I'm not sure if the new software was the same as the old, but if you load the program to run not edit you should be ok.
Regards Mark.
