Old 08-07-2008, 06:19 PM
neilw20's Avatar
neilw20 neilw20 is offline
neilw20 is on a distinguished road
Smile The finish !
Really good. With Z steps of 0.25mm you could just see the line but in no way could I feel it. With a final measure on last pass on this job maintaining 0.01mm between parts and I stacking two parts and turning around parallel surfaces within 0.003mm as best I can measure. Job tolerance is +/-0.01mm
so I am happy with it. This was on CR12 stainless steel which is the stuff used for making knife blades in meat munching machines.
B1tch of a job to clean the machine afterwards. This gray gunk like all grinding machines seem to get. Need different coolant for grinding maybe.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
