Yes the D is usually a Diameter register where the diameter value is stored.
So your first move should be at least 2mm which it look like it is, did you try doing the Z move on a separate line before or after? see if that makes a difference.
Al
__________________ CNC, Mechatronics Integration and Machine Design.
Albert E. |
