Originally Posted by gunlocators Another stupid question....
What is the purpose of a breakout board I was under the assumption the controller hooked direct to your pc parallel port...
You use a breakout board when you use individual drives with each axis. Typically the 3 in 1 and 4in 1 boards do not need them. You also can use a breakout board to connect additional limit switches, relays, and other stuff. you can do this on a second port.
Also whats your thoughts on optical limit switches???? |
Dust will probably trip them, and you will have dust.
