Thread: Need Help! No rapid on Z Axis with G0
Old 08-05-2008, 03:24 AM
kdhBOSS5VRAM kdhBOSS5VRAM is offline
kdhBOSS5VRAM is on a distinguished road
What are you programming?
What are you programming that you need two rapid moves in Z in a row? From what I see it should rapid directly to the Z.1 line basically ignoring the Z.25 line and then feed to the Z-.375 line. The only way it would work the way you have it would be in single block.
Also to call up cutter comp correctly you need to ramp into it giving it enough distance to comp it correctly. On the older BOSS control I think you have ramp into it perpendicular to the path where on most you can just angle into it. Either way you need to give it some distance to let it pick up the cutter comp. Hope this helps.
Kevin
