Hi Brad,
Don’t know if I can be of much help. I haven’t used a BOSS 6 controller. Mine are BOSS 10. I know that the BOSS 10 can be fussy about cutter comp and I see a G41 in your program. Make sure you are cancelling (G40) the cutter comp when finished.
I thought someone once told me that in the earlier versions of BOSS, you had to have a zero in front of the decimal point for values less than one.
Have you tried shutting down and restarting the machine? If so does it run the program correctly on the first run?
Try to run a program that you know is good (let the machine cut air) and see if it runs right. That may tell you if the problem is the program or the machine.
Good luck |
