under file there is a prefreence section you need to fill out the baud rate and such for your machine. If you are not sure st the rate low.
I think the DNC send is under file as well. I use a 3rd party softare for editing and sending so it has been awhile since I used Gibbs for DNC.
Also I would suggest you call Gibbs direstly if you need help. They may charge but if you are in a jam... |
