I have only had a short play on one of those Excitech DSP pendant thigies.
But as I remember there is a parameter on it you can set to make it take feed rates from gcode.
If this is not set then it takes no notice of the feedrates in the gcode and uses whatever feedrates are set on the pendant.
Also I believe, there is no way to make it set spindle speed from gcode. That must be set manually on the VFD.
Greg |
