Guessing the low voltage may be causing the motors to draw more current than the drivers may be able to handle.
Or the inverter is outputing really dirty D.C. running at its maximum capacity.
You will have a much better answer once you try the two battery combo.
Might suggest using a 36 volt inverter however it still only has a 270 watt continuous rating.
JoeyB |
