Old 07-31-2008, 03:57 PM
dharschman's Avatar
dharschman dharschman is offline
dharschman is on a distinguished road
T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER)
I am trying to grind a 6 tooth solid carbide t slot cutter, 3 teeth right hand cut with 5 degrees right hand axial flute and 3 teeth right hand cut with 5 degrees left hand axial flute. Cutter is .297 wide with .020 radius on front and back of each tooth.The front and back face of cutter has 1.5 degrees dish with 2 degrees side clearence. Can this be ground completely in p5? (first time using p5)
Right now I am piecing it together with p4 , p6 and p32 wich seems to be some what of a hassle but it will work for this time around.
