Thread: cutting a slot
  #10
Old 07-25-2008, 11:26 PM
Mike Stevenson Mike Stevenson is offline
*Registered*
Mike Stevenson is on a distinguished road
Here is what I think you are doing:
1. you select contour milling.
2. you select all your chains (geometry) that you want cutter comp on and off.
3. you think you can do it this way.
4. no you cant do that.
5. 1st do a contour toolpath and select the chains you want comp off and turn the comp off in your settings.
6. 2nd do another contour toolpath and select the chains you want comp on and turn the comp on in your settings.
7. the comp on and comp off toolpaths cannot be done in the same operation - they must be separate.
