Thread: Problem motor over load #12
Old 07-24-2008, 04:26 AM
Delw Delw is offline
Delw is on a distinguished road
had some time again and dicked with this on some thread milling it just wont thread mill anything.
it also gives me a #12 error on the z axis sometimes when running a g18 go3 code,however when I reset the machine it will run the program for a week or so so the error is intermittent unless its thread milling then it is always the x axis #12 error
took the mem card out like Neal said do a reboot same thing to see if its a memory card.
someone mentioned that it might be gain? change from high to med?
also mentioned to put a ground rod into the ground or a water pipe.
this weekend I will have some time to dick with it so if you have any ideas I would appreciate them.
