Well if it is solid there are no Normal issues as a solid is a single water tight model. as for the gaps as you are calling being were the tool lifts what type of paths and are you setting gap setting. if you see gaps in the surface model bigger on one computer to another look into the shade settings. there are a tollrence settings that can make them better but this has nothing to do with cutting. do you want to share the Solid works file. being the SLDPRT file?
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management)
Cadcam
Mastercam Instructor , Programming Consultant and ME (Manufacturing Eng) |
