hello,
still looking for the cheap one.
but i can say that in order to do it you must be used to trim servo i have seen that the response must be less nervous if you have mechanical backslash
i can imagine that a lot of tester have been trapped by that because you like to have a very fast feeling this is a wrong approach , make it slower to respond so your servo will not hunt and then make it a bit more nervous but never forget that this is real motion and not an elasticity or a compression it's a full load real move !!! that's why it should be cool
uhu is perfect for this job Mr. bunamis you should try it and i am sure that you will have something much better 1/10 th mm |
