Hi Tony, heres a couple of photos I already have. I'll take a few more so that you can see the mounting.
The mounting will differ from make to make but the principle is the same I think.
The pulley size is about 160mm in diam with a B section Vee belt.
Some of the air-con compressors have twin vee belt drives.
I think your lathe has the drive directly into the top of the headstock casting with the motor down near the floor.
Ian. |
