Originally Posted by gio1976 Sir PEU, your profile also didnt workout(screen looks like mach3mill). Am i doing something wrong?
Tried all combinations on the switch on c6 lathe. nothing worked, except when spindle is on manual. There's no spindle and flood control sockets. x, z and spindle "encoder" wires all cramped into one socket.
Is it possible syil china used different ports?
thanks. |
The XML has nothing to do with the screen, are you sure you are launching mach3turn?
After you launch the XML I sent you, go to screens and load the default Lathe screenset, this should do the trick
To launch a specific XML go to mach3 folder and execute the mach3 file, it will give you a list of all the XMLs you have in that folder.
Good luck!
Pablo
