Try this. | | The ports and pins for the C6 are similar (if I remember, but don't quote me) to X4+, so try the same profile on the C6 as a starting point. Make sure you you use a renamed copy and call it C6TURN instead of X4MILL if you are using the same PC.
Beware that the charge pump might be stopping it working.
There is a jumper on the BOB near the center close to the limit switch terminals. Moving this to the other position might get things going, by disabling the charge pump, but you should eventually make it work with the charge pump operational. Look at the pinout documentation that came with the machine. Syil sell the machine. Not Mach3. That's your part. |
