AG60 = .059 distance from side of insert to centerline of point.
A60 = .035 for same dimension
32UN = .020 for same dimension.
One thing to realize is that a slower RPM will allow the insert to get closer to the shoulder before starting to pull out. Unless you use 00 in the 2nd pair (for G76 2-block call) which will leave a ring next to the shoulder. Use 01 to pullout over the shortest distance. |
