The advantage to differential driver comes when both A & /A etc are used for noise elimination on long conductor runs, if using only one output, you may as well use the single ended output direct as shown in the first link.
If you really wanted to use differential but only had single ended input at the receiver, a 26LS32 receiver could be used.
__________________ CNC, Mechatronics Integration and Machine Design.
Albert E. |
