For those running an indexer here is a email of Rich,
rgoldner@iname.com, who has written 2 wizards so far for the indexer. I have been working with both and they are great. Rich is a retired programer who has been building CNC machine running Mach since Mach's early years. He also helped a friend upgrade his Legacy Ornimental mill to CNC. The perfect background for doing indexer wizards.
One wizard is to do spiral cuts. Designed mainly to do rope/barley twists. It allows to use A, B or C as rotational axis, do CW or CCW twists, select depth of cut, etc. Here is a 14" piece I did.
The other wizard will wrap a file around a cylinder using A, B or C as the rotational wizard. Both work great and he is going to write more.
The other option is
http://legacywoodworking.com. They have released the beta version of a spread sheet that will do rounding, fluting and rope/barley twists. Price is $100. Right now it's only advantage over Rich's wizards is that it will do fluting. Hopefull Rich will fix that shortly.
