Originally Posted by snovak240 Sounds like you have a start. One thing is if you plan on getting a place to put eveything figure out what size you think you need and then DOUBLE IT. I believe the CNC can be the way, but with the cost of the equipment, what I did was got myself a lathe and a milling machine and then when the work started to come in went for the CNC lathe and mill.It allowed me to put a large chunk of cash down so the payments wernt over the top. I still have both of them and use them to qualify or do second opps when the cnc is running. Something else to think about....
Good luck to you.
Stan Novak
Century Machining
58 Century St
Brewer Maine 04412 snovak240@aol.com |
I could get old manual mills and lathes cheap these days. I also know how to rebuild them. But the technology is going away from these.
