automatic touching off of tools and x/y alignment? | | I'm new to cnc and took a class at school to run the Haas machine there.
The initial set up requires I touch off each tool I'm using and save the z-dir and also align the program zero point.
This seems to be a very manually intensive process. Are there machines/tools that automatically touch off the tools?
For example, if my g-code uses T1, T2, T4 then can't the cnc touch the tool with some sort of sensor and know when it hits the table (i.e. like an auto calibrate).
For the x/y position, I suppose I can set up stops so that work zero is the same place. I've searched this forum and saw some guys use a laser cross hair.
What does everyone else do to speed up the Touch off tool and program zero points?
Tanks in advance! |
