Old 07-11-2008, 11:26 AM
Geof Geof is offline
Are you sure it is the spindle and not just the belt? These machines can make a lot of belt noise if the motor is misaligned and the belt rubs against the side of the pulley. If the spindle nose does not get warm when it is running constantly and if there is no problem with accuracy I would suspect belt noise.
