For the proper meshing distance the Pitch Circles of the teeth on the Rack and Pinion are set tangent to each other, or in the case of the rack the Pitch Circle is NOT a circle it is a straight line so the pinion PC should be set tangent to the PC of the rack.
You can look up the Pitch Circle (PC) data in the machiners handbook or a gear data book.
__________________ Thanks
Jeff Davis (HomeCNC)
http://www.homecnc.info
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
