Old 07-10-2008, 06:57 AM
bad-rat-57 bad-rat-57 is offline
bad-rat-57 is on a distinguished road
Should torch always be over metal to fire ?
Is there any concerns about where the plasma torch is fired ? Should the torch always be over metal when fired. I'm wondering if there will be problems with the electronics by having the torch fired in air if you were to lead into the side of the material for instance in cutting thicker plate vs plunge cutting.
