The bulbous nature of the gear is the correct gear form and the guys are right about the meshing, if for example you laid a piece of thin tissue over the rack you would find it would run smoothly as it would keep a meshing distance between them, it you spring load the pinion then it will ride up if it gets stuck, I have seen this done to elliminate the backlash.
Graham |
