Just courious but what were your feedrates? What kind of cutter? Diameter? Coolant? How many flutes? Climb cutting of Conventinal? Depth of cut? step distance?
Also how did you find the parts center?
On the uncommanded plunge did you check to see if that was a mechanical issue? another words was Z0 still in the same place? Did the machine fall and Z0 now looks like Z-? Did you check to see if the CUTTER slipped down?
__________________ Hey check out my website...www.cravenoriginal.com
Thanks Marc |
