Old 09-14-2004, 08:04 PM
ToyMaker's Avatar
ToyMaker ToyMaker is offline
ToyMaker is on a distinguished road
Interesting idea.
Raw data comes off a CD at something like 44kHz. The drive motor is in a servo loop such that the disc passes under the head at a constant rate, a process called constant linear velocity (CLV). When the read head is near the inside edge the disc spins fast (>300 rpm?), and when near the outside edge it is slow (~100 rpm?). Because there is only one track on a CD (similar to a phonograph record) there would have to be a way to step the head out each revolution.
If you could record a (very) constant tone so that there were a known number of wavelengths per revolution, couple the shaft to your cnc machine, and count wavelengths, the whole thing just might work.
I think the index step each revolution might be the big gotcha.
robotic regards,
Tom
"Some politicians like to move their lips, and apparently, some lips like to move politicians."
- - Shan Jones
