A source for 1/4 - 4 acme leadscrew? cheap of course! | | Any sources for a 1/4-4 ( 1/4 od 0.25 lead single start) 36" leadscrew in stainless? I've tried a few, (msc, roton, techno isel) and Nook has one on the books but its $78 or $601 with machining..... This is stainless but if pushed I could use 4140 or something similar.
Here's the problem; I've a large format plotter, 36" wide pen type from Mutoh that has a wear problem on a leadscrew. I've had it for about 14 years, heavy, built like a tank but recently has been stalling the x stepper and screwing up the plot. Now can't reliably plot at 50ipm, it used to do 800ipm with pencil on vellum... The leadscrew is stainless and the nut is Bronze and it's galled in the most used area, on the left by the pen carousel. It's machined such that I can't swap ends.
I want to replace/repair it but the arrangement is a little different from most. It uses a fixed, non rotating 1/4-4 acme profile leadscrew and a linear stepper which has the shaft replaced by an internal rotating nut in bearing bronze. I've sourced a replacement motor or two from ebay, cheap, and thought that would be the problem. Now I just need to find the leadscrew and off we go. Nook's machined price is worth more than the plotter is..
So, any ideas?
thks
Andrew |
