NO I'M NOT GETTING MARRIED
The title is to differentiate what I want from other kind of rings.
Yesterday I offered my wife to make a copy of her gold ring in titanium, I needed a project to improve my CNC lathe skills and it sounded good, so there I went.
The dimensions of the ring are: OD: 19mm ID:16.5 width: 4mm
So before starting in TI I decided to test in 7075 aluminium to anticipate and practice the difficult operations:
1) reduce diameter to 19mm - DONE
2) Make hole - Done
3) Bore to 16.5 - DONE
4) make inside diameter fillet - DONE
5) make outside diameter fillet - DONE
6) parting - DONE
7) use a collet to hold the piece and face it to 4mm width - DONE
8) make inside diameter fillet (the other side)- DONE
Here my problem begins, the collet needs about 2~3mm to grip the almost finished ring leaving almost no space to make the outside fillet, do you guys have an idea about how to hold the almost finished ring to make the final outside fillet?
My idea is to make a fixture with an expanding screw to hold the ring outside, with enough distance from the chuck to turn it. What do you think? Other completelly different methods for turning a ring are welcome too!
Thanks!
Pablo
