Hello
I have a 3 axis K2 machine with 24vdc motors, 250 line encoders and Gecko 320īs to a PMDX 122 board. The machine stops at random, and triggers the fault input of the pmdx and Mach3. Mostly the machine stops when i run it faster about 3000mm/min (5mm pitch screws and 2:1 reduction). I have changed the power supply with no result. All the cables are changed to shielded tp for the encoders etc. I donīt know why the geckos are faulting either the encoder signals are bad or the power supply, i just have this problem several times a day. Perhaps i need to put in line amplifiers on the encoders (usd) to boost the signals? Sometimes Mach3 show an estop but the geckos are still enabled, sometimes the same estop is displayed but the gecko drives are faulted too. When they are i have to home and zero the machine again. The enable outputs on the geckos are paralleled into the fault input, so i cannot tell wich gecko that trips the fault, would be nice to have them separated but i only have one fault input on the PMDX board. What is wrong then?
Pete |
