Thread: Servomotor
Old 09-12-2004, 05:45 PM
Alex S.A Alex S.A is offline
Alex S.A is on a distinguished road
Originally Posted by Al_The_Man
I get the impression that you used to have 2 motors controlling one of the axis on this machine? and now you just have the one , is this correct? If you have modified the configuration from a double motor axis to a single it will depend on how the axis were synchronised in the controller. For example, Galil and Acroloop controllers have a command such as axis lock or a way of synchronising each motor, so if you have modified the machine you may have upset this synchronisation. What controller is on this Machine? is it a PC based control?
Al
Since the first thread I said that there is just one motor. I did not change the machine. It is its original configuration. The controler is a CNC model ANC 401 and the driver is from Axor. That configuration is not necessary synchronism right? If so, what do I have to do?
thanks Al,
Alex S.A
