you over traveled on the hard limit switch ( torque switch ). place a 2x4 pc of wood between the the turret and spindle( it may be your x axis you should know which one was hit ) and gradually crank the hand wheel in the minus direction until you hear the pop of the switch go back in position. hand wheel should be in .001 mode. sounds like you or some one crashed and burned
__________________ If you can ENVISION it I can make it |
