I get the impression that you used to have 2 motors controlling one of the axis on this machine? and now you just have the one , is this correct? If you have modified the configuration from a double motor axis to a single it will depend on how the axis were synchronised in the controller. For example, Galil and Acroloop controllers have a command such as axis lock or a way of synchronising each motor, so if you have modified the machine you may have upset this synchronisation. What controller is on this Machine? is it a PC based control?
Al
__________________ CNC, Mechatronics Integration and Machine Design.
Albert E. |
