Originally Posted by ynneb Alex, I am guessing that you mean by "jumps along the rail" that the servo is constantly trying to correct itself. Is it vibrating? If this is the case it may be an idea to tune your servo driver card. Does your driver card have trim pots that you can adjust? |
I think so that is what you said but what I think strange is : there is just one servormotor. I got a such problem and the encoder servomotors in longitudinal rail's parameters were differents , when they should be the same value. Now there is one motor and this is happening. Do you think that this problem can happen in this conditions? Why?
The machine cut sheet and the measurements of the parts cut are the same as set before.
So that I think that the enconder is not the problem...
