Old 07-03-2008, 02:41 PM
Cairns Cairns is offline
Cairns is on a distinguished road
Machining snap ring groove
What tooling would I use to create a groove that a snap ring would fit into? For instance if you had a bearing in a bored hole you'd use a snap ring to keep it seated. Currently I'm using a boring bar that I've ground down to the right profile but it seems like there should be an easier way to do this, particularly for very small grooves, like to hold a 16mm bearing in place.
