Hello,
I've been losing more and more time lately reading up about the DIY CNC movement, and I'm working up the nerve to start putting together a mill of my own. I'm still in the research phase right now, but I'd be interested if anybody could answer a few easy questions. If there is a nice DIY-CNC FAQ kicking around somewhere, I'd appreciate a link.
1) How do you manage to cut out parts using these kinds of router mills? I understand that you just plunge the bit in and carve out the shape (a little deeper each time) but doesn't that gouge up the surface supporting the piece? Are the machines so precise and well calibrated that they skim along the top without damaging it?
2) I hear threaded rod described in terms of two numbers (1/4-20). What do those numbers represent? Is it diameter and thread-count?
3) I (think I) understand the pipeline that takes the design in one end and burps out g-code from the other. How challenging is it to calibrate your CNC mill to accurately produce your designs? I mean, if for some reason my x-axis translates slower than my y-axis, my software needs to know so I can draw a square, or else everything might come out squashed. Is this a concern? Or is this why we use the same hardware for both axes?
I appreciate your time in reading this. I'm thinking about buying the plans and attempting to make the 7th Sojourn. I'm interested in doing relatively small bas relief projects in wood. Its cutting area, precision, and price seem to fit and I've found favourable reviews of it around the internet. I hope to come back soon with some more technical questions regarding the actual building!
Cheers,
Rob
