Old 09-10-2004, 11:54 AM
icm icm is offline
icm is on a distinguished road
3D/2D PIC PWM Step/Dir CNC Controller
Technical specifications:
- Standard, 3-axis or 2-axis (3D or 2D), Hybrid/Native PWM, Step/Dir-system CNC motor control.
- Unipolar motor drive, with 12 pieces of Logic Level MOSFET power transistors (with integrated protecting supressor diodes).
- Possibility of mounting an external optional heat sink (for the FETs) (not necessary if load does not exceed 2.5A/phase).
- Input voltage and power supply range of the motors: 8 ... 50 V or 8 ... 90 V
- Maximum driving phase current of motors : 18A (above 2.5A heatsink is necessary, above 5A reinforcement of conductor stripes of PCB is necessary).
- Minirelay with potential-independent make contacts for controlling the turning motor or the filament (maximum. ~250V, 5A).
- PC interface: standard CETRONICS interface female for standard printer cables (LPT port).
- Microcontroller: any 40-pin member of the PIC16F87x (16F871 ... 16F877) family with 20MHz clock.
- Step/Dir signal detection (by the means of two-way counters).
- Full galvanic separation from the PC, by the means of opto-couplers.
- Built-in 5V supply (necessary input voltage: +8 ... +12V).
- Built-in ICP (In-Circuit Programing) interface, for uploading Firmware/Setup.
- PCB-integrated PIEZO speaker (for signal sounds)
- 3 pieces LED drive (Power supply, LED1, LED2) for combinated signals.
- 1 push-botton for obtaining signals and functions.
- Full compatibility with Hobby and Profi Firmwares.
- Serial datalink (PC-Link). Direct Setup uploading (PWM) and extended diagnostics.
Please visit: http://magiist.free.eplanet.hu
