Old 09-09-2004, 09:34 AM
High Seas's Avatar
High Seas High Seas is offline
Gold Member
High Seas is on a distinguished road
Question How to set up Tool Offset in MACH2?
Here's something I could use some help on.
How do you set up tool offset?
Here is what I've done so far - read the book - Yep
Searched here and Yahoo - Yep.
And, I have set up a tool in the Tool Table, given it: a name, a diameter, z offset (0) material, etc.
Used the ENTER key and even Saved the Table.
Selected the Tool Number, and then went to the Offsets Tab (ALT5).
Checked that I had the tool number selected and the diameter was the same.
BUT THEN, I note the Program Extrema (on ToolPath Alt4) doesn't change indicating the offset is there!
I've been playing with the wizards for circle cutting. When I use the wizard and change the offsets, the Program Extrema DO change - reflecting the change in offset.
I note that an M code is in the code when I use the wizard. I checked it and its for a tool change. Is that what sets the offset? I want to set offset in MACH2, not the cad file.
Help!!!! What step am I missing? Is there something I need to do in config?
ANYbody? TIA - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
