Old 09-09-2004, 08:39 AM
Al_The_Man's Avatar
Al_The_Man Al_The_Man is offline
How big is that solenoid valve? Did you measure the 5.4 amps or is that printed on the valve? For a 115v solenoid that is a really high current unless it has a huge coil. A typical reading after initial inrush is usually less than 1amp for a 115vac solenoid. Also it is not unusual for a breaker to appear to trip immediatley if the armature does not move when energised.
BTW in your first post you mentioned that the breaker is rated at 5amps!
Al
