Thread: New Machine Build What just happened???
Old 06-28-2008, 10:20 AM
mulligan mulligan is offline
mulligan is on a distinguished road
Originally Posted by Ajax-oz View Post
Is your cutting bed, part of the CNC gantry
Yes. I have the typical 5/16 roller blade bearings for the gantry rollers.
Do you have both cutting bed & gantry Grounded using a very good ground. 1" - 2" wide (depends on plasma size) Braid earth cable (works the best) on both cutting bed and gantry. one each
Nope, but I will definitely install them.
does the torch have an Isolation block that it is mounted on.
I have an aluminum block the compresses around the ceramic cup on my torch handle for a torch mount. This block is mounted to a piece of HIWIN rail and then to HIWIN bearing blocks.
I'll try to get pics but I have dial up and is extremely slow.
