  #11
Old 06-28-2008, 06:34 AM
ger21's Avatar
ger21 ger21 is offline
You probably should work your way down slowly, checking along the way to make sure it's cutting OK. Start at around 18,000 and work down from there. What size bits are you using? small bits might need to spin faster than 12,000.
If your using steppers, you really can't damage them, unless you take them apart.
